Help! I broke some coolant sensor
Old Apr 4, 2001 | 01:31 PM
Casey'91Z28's Avatar
As I was taking off my old exhaust manifold on the passenger side I broke the connection to a sensor. I took the sensor out and let all the coolant out. The sensor is in the middle of the block(or the head, not sure) underneath the exhaust manifold. There is a pin that goes into the sensor, I think it is the coolant temperature sensor. The pin goes into the sensor but it will not stay in. Does anyone know what sensor this is and how I can fix it? I really need some help I did a search and couldn't really get a clear answer. Info on my car is in my signature.
'91 Z28 305, Auto trans, K&N filters, TPIS air foil, power pulleys, ported plenum, hypertech chip, hooker cat back, kyb shocks, STB, 14.7@ 93 mph.
Old Apr 4, 2001 | 02:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Really need to know if it's in the head or block. The head has the fan switch, block is the knock sensor. Does it have about the same size body as threads (switch), or is the body a lot fatter than the threads (knock sensor)?
Either way, from the current condition you describe, replace it. Since you've already removed it, take it with you to the parts store.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, TBD heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Apr 4, 2001 | 08:33 PM
ede's Avatar
ede
my guess is the switch for the fan, you'd really have to try to get to the knock senser. the fan switch is in the head, as you've been told.
ICON Motorsports
1st & 3rd
92firebirdguy
Sep 1, 2016 07:53 AM
L98GTA87
Oct 19, 2015 10:43 PM
corey8084
Sep 17, 2015 02:56 PM
m00n420
Sep 11, 2015 02:39 PM
FormulasOnly
Sep 10, 2015 09:07 PM
