V-belt to Serpentine swap
Old Apr 3, 2001 | 01:30 AM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
I have to change over to 134a and in the process I'd like to swap to serpentine belts. Would like to know if the pulley from a serpentine belt will work on my old compressor? Any recommendations on engines to take brackets off of? Thanks.
Take 'er easy, and if
she's easy, take 'er twice!!!
Old Apr 3, 2001 | 09:28 PM
Hummer's Avatar
Car: 1986 Z28
...anybody???
Old Apr 3, 2001 | 09:32 PM
burnoutrpm's Avatar
i know this isnt much help but, i didnt think you could switch the pulley on the ac compressor?? if there is a way i will stay tuned in for the answer!
89 firebird formula
356 10.5:1compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
Old Apr 4, 2001 | 09:03 AM
Mark W. Winning's Avatar
I made the swap on mine. I ended up replacing the a/c compressor. I have a working v-belt compressor and a bad serpentine compressor. THEIR clutches did not interchange. Even though the units looked the same, the shaft was different and the clutch assembly would not interchange. I am not sure if this is a year/model issue or a v-belt vs. serp belt issue though.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old Apr 4, 2001 | 09:36 PM
John Boy's Avatar
I think Willie has done this and said that the assesories were different in more ways than just the pulleys. Can't remember for sure and I have 0 luck with that search thing....anyway after reading his comments on the subject I order the serp kit from www.tacreationsusa.com and will install next week.
Old Apr 4, 2001 | 10:11 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
i think you will have to change water pumps too
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
mustangdmurder
Aug 21, 2015 07:17 PM
jahblah
Aug 12, 2015 05:54 PM
