Owners of Comp Pro Magnums, need help.
Old Jun 17, 2004 | 01:33 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I have Aluminum Roller Rockers now and they are VERY noisy. They are adjusted right and they don't tick, just when the motor is hot like in town and I stop next to another car, you can hear them chatter. I have heard this is normal with ALRR, but I hate it. I want something quieter. I would like to avoid a stock rocker arm. I have narrowed it down to Comp Pro magnum's full steel rollers, or just the Magnum's with roller tip. I have a set of the comp magnum's now on my truck and it is bone stock quiet. I want the Pro Magnums but I am worried that they are noisy from loose bearing clearances at the stud like the Aluminum ones. So my question is...
How noisy/quiet are The full roller Pro Magnum's?
Worth the $330 for them?
Old Jun 17, 2004 | 01:43 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They are somewhat noisier than stock or the Magnum rockers, but much quieter than typical aluminum roller rockers. They make a light whirring noise as opposed to the usual clatter.
Of course, you may have other sources of noise, that changing the rockers won't cure; anything from push rods loose in whatever guides them, to valve springs with outers that rub on inners, valves loose in their guides, etc.
You've got a real mild cam though, barely more aggressive than stock, it's nothing like the really hot ones like the Comp Extreme rollers or any of those, so at least you shouldn't have just an overall elevated noise level.
As far as "worth it''..... it was "worth it" to me, but that's just me. But of course I didn't pay anywhere near that for them.
Old Jun 17, 2004 | 01:50 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
$265 from summit:
http://store.summitracing.com/defaul...rt=pro+magnums
Old Jun 17, 2004 | 02:05 PM
GASGZLR's Avatar
Originally posted by MrDude_1
$265 from summit:
Not for the self-aligning ones.
Do you guys think I would loose power by going to a regular magnum versus the pro magnums? I take it to 6000 rpm.
Old Jun 17, 2004 | 05:33 PM
YenkoZL1's Avatar
Car: 1991 RS Camaro
Engine: Custom Built 327
Transmission: Tremec 5-speed
I have the Pro Magnum 1.52's on my car and they are some what noisey but nothing you cant tune out. I prefer the Pro Magnums because of the Chromolly Design and the fact that they are rebuildable. So I thought $256 was well spent for me.
Old Jun 17, 2004 | 07:28 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Here ya go, striaght from thunder racing:
http://www.thunderracing.com/catalog...vid=6&pcid=108
63-1318-16 Comp Cams Pro-Magnum Self-Aligning Roller Rocker Arms, 3/8" stud, 1.6 Ratio (Special Expires 06/30/2004) $258.30
Old Jun 17, 2004 | 07:31 PM
CraZ-28's Avatar
Car: 1991 Z-28
Sorry, just noticed you had 1.5 but they are the same.
Old Jun 17, 2004 | 08:01 PM
EvilCartman's Avatar
Car: '82 Z28
I run the pro magnums... Dunno how much more noise they produce because I'm running a solid lifter cam but they're a great rocker. Here's a pic, these aren't the self aligning ones though.
Old Jun 18, 2004 | 08:53 AM
GASGZLR's Avatar
Nice! Super clean. That is a good price for those rockers too.
Can someone guess if I would loose any power buy going to the regular magnums?
I am willing to give up like 5 hp for a silent valvetrain. It was cool at first to have this thing chatter and clatter, but now it is annoying. I have heard that these Proform rockers are the noisiest ones of all.
Old Jun 18, 2004 | 08:57 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Proform rockers
You usually get no more than what you pay for. Pay the least, expect to get the least.
Yes you will lose some power; no I doubt it will be much, probably not even 5 HP. The single biggest effect I'd expect to see would be increased oil temp; as the rocker ***** are probably the hottest moving part in an engine, especially at high RPMs. Rockers get hot enough there to color the metal. Rollers cure that.
Old Jun 18, 2004 | 09:20 AM
GASGZLR's Avatar
THanks RB, the reason I ask about the Magnums is because I have a set on my old work truck with less than 1,000 miles on them and I was thinking about swapping them to my car to get it quiet.
Old Jun 18, 2004 | 10:18 AM
RebelTillDeath3's Avatar
Car: 92 Camaro
Whats the difference between the Magnums and Pro Magnums? If I went with the 1.6, I'd need taller valve covers, correct?
Old Jun 18, 2004 | 10:27 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The Magnums are roller-tip with a ball fulcrum. The Pro Magnums have roller trunnion instead of a ball fulcrum. They're really rollers.
Rocker ratio has nothing to do with valve cover height.
Typically you need taller valve covers with any roller rockers, because they use Poly Locks instead of lock nuts, which are much taller. You can see them, and how tall they are, in Evil's pic.
Old Jun 18, 2004 | 10:34 AM
Car: 92 Camaro
I'm going to be tight on money for a loooooooong time (moving), so would the regular Magnums be okay? What type of gains would I see? And am I losing my mind or does Summit not have any center bolt valve covers?
Edit- I have a stock cam, would 1.6 or 1.52 be better?
Old Jun 18, 2004 | 06:03 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Probably nothing. Sorry, but you really must rev rollers pretty high before they loosen up some extra HP. Roller tipped rockers probably don't gain anything except marginally lower oil temps.
Old Jun 21, 2004 | 12:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You might not get much more power, but they reduce side-loading which greatly reduces wear on the valve stems and valve-guides.
Old Jun 21, 2004 | 02:56 PM
Engine: 305-4v
Chris,
Send me your new email. Tried to send you a cool column on teleportation but it bounced back
Old Jun 21, 2004 | 03:27 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Haven't changed my e-mail in years.
Old Jun 21, 2004 | 04:53 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
most roller tip rockers will also give a much more accurate and stable valve lift compared to stock stamped steel rockers.
Old Jun 21, 2004 | 11:18 PM
GASGZLR's Avatar
THAT'S IT! I have had it with this dumb chattering. It is very annoying, my motor sounds like crap. I am going to order a set of Comp magnums tomorrow. These chinesium roller rockers aren't going to cut it! Some guy just now in town was like" That thing sounds like it has a huge solis lifter cam in it, does it?" I guess that is kinda cool, but if the valve train was quiet, the car would be a sleeper at idle.
Old Jun 22, 2004 | 10:10 PM
GASGZLR's Avatar
update
I changed the rockers from the proforms to the comp magnums. I did notice that the magnums were lighter as far as rotating mass. Anyway, I thought I would loose some power, but instead it feels WAY more powerful! Maybe it is the precision 1.52 lift that comp has. I revs smoother and the motor feels tighter. I should have put these on in the beginning. Oh yeah, it is almost like factory at idle, give of take the lope and the headers, LOL.
Thanks for everyones input
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
84 TA NV
Sep 6, 2015 08:02 PM
85Special
Sep 3, 2015 04:21 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
