Why does my gas gauge read sideways?
Old Jun 18, 2004 | 06:45 PM
krly79's Avatar
Car: '93 S10 Short bed standard cab
Engine: 383 Stroker
Transmission: 92' stage 2 700r4 w/3600 stall
Well, like the subject says, my gas gauge reads sideways and I don't know why. Does anyone know why?
Old Jun 18, 2004 | 07:35 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Ok... think I get it now... It might be due to the fact that the needle is off. Did you take apart the dash? Try to recalibrate it by filling the tank and pulling and setting the needle to the full position.
Old Jun 18, 2004 | 07:49 PM
krly79's Avatar
Engine: 383 Stroker
I have taken apart my dash, but I have never touched the gas gauge. That's what I don't get. I have never taken the needle off at all. How does the needle come off?
Old Jun 19, 2004 | 01:38 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
it's just pressed on, mine are so worn from "re-calibrating" as mentioned above that some of them fall off at will (my speedo mostly) and I had to glue them on
Old Jun 19, 2004 | 03:52 PM
krly79's Avatar
Engine: 383 Stroker
Well, I fixed it. I just filled the tank up, pulled off the needle and put it on pointing to full. I just don't understand why it wasn't reading right because I've never pulled off the needle. Oh well, it works now. Thanks.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
355sbcTPI
Aug 19, 2015 04:38 PM
BurlyChev
Aug 16, 2015 09:08 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
