fuel pump changover
Old Apr 7, 2001 | 08:34 AM
JunkHead84's Avatar
fuel pump changover
how hard is it to change over from an electric fuel pump to a mechanical one. Whats involved? thanx
Old Apr 7, 2001 | 09:46 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Its not too hard to do if you buy the right parts, but it can be time consuming running the wires and attaching the new fuel lines. If you haven't done the swap before you might want to look into getting an electric fuel pump wiring kit from Painless. It comes with the relay, circuit breaker, wires and diagram which makes the job a lot easier.
As far as the mechanical part goes buy a block off plate to cover the hole where your mechanical pump was. Also find a good place to mount the new pump, I mounted mine back by the tank. And depending on what kine of pump you get you might need a regulator and return line. I recommend the Carter pumps, they are quiet and don't require a regulator or return line on certain models. Just to be on the safe side I added a regulator and pressure gauge even though its not required.
Good luck!
best 1/4 mile so far: 13.4 @ 101mph
84 Camaro 305 ported & milled heads, 3 angle valve job, Edelbrock Performer RPM intake, Hedman full length headers, Accell ignition, Crane 274H cam, B&M 700R-4, 3000 stall speed, 4.10 gear,
M/T ET street tires
visit my website at http://www.geocities.com/jbenge/page1.html
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
