Another flexplate question...
Old Jun 23, 2004 | 12:06 PM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
I have random pinging on startup... as in there is no pattern to the noise, so it can't be engine. Also, I took my dust cover off of my tranny to make putting a starter in easier, and now the car has a random growl to it, a pretty distinct mean sounding growl, from everything I've read, this definetley sounds like a flexplate issue... (the noise appears to be coming from under there too) anyways, my question is if it was just a loose flexplate, would the looseness be real obvious? like should i be able to wiggle it? cause i can't move it at all and it doesn't appear to be cracked anywhere, ive never had one of these go before so i really don't know what im looking for and i just didn't wanna go tightening it if it was already.... thanks.
Old Jun 24, 2004 | 05:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The whine sounds more like the front pump. Could be normal, may be sign of something not so good. Depends upon the degree.
A cracked flexplate can make some weird sounds and not move when wiggled by hand. About the only way you can know that is remove it and inspect.
I haven't seen it personally, but I've heard a bad sprag can make weird noises as well.
Old Jun 25, 2004 | 03:16 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
oh yeah.. mine defently made some strange noises.. sounded like a cracked flexplate at first.. then turned into an aweful screaming sound.. intresting noises to say the least.
Old Jun 27, 2004 | 02:43 PM
grndmasnightmar
Guest
Posts: n/a
well
my flexplate just went and there were no symptoms just dashboard started to shake hard and then i shut off car went to restart and the car just made a grinding noise. the flexplate broke a clean circle around the center bolt holes. i saw a little stress crack in the center which split to one of the bolt holes then from there went one hole to the next. use a flashlight and look up there to see any small cracks..maybe thatll give u some piece of mind..
84LsxZ28
May 17, 2020 02:21 PM
Stangski09
Nov 14, 2015 01:27 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
roysatikas
Sep 22, 2015 08:15 PM
roysatikas
Sep 7, 2015 08:08 PM
