TPS voltage through Terminal?
Old Apr 7, 2001 | 11:37 PM
Keith5's Avatar
Car: C1500
I was reading this and got the jist that we can read the TPS voltage through the dianostic termial. Can we, and if so which terminal's is it?
https://www.thirdgen.org/messgboard/...ML/007593.html
Edit: This is for my '85 IROC TPI
1989 Pontiac Firebird Formula LO3 Auto
-180 degree stat
-Hooker Cat-Back
-vinyl security shade, velcro t-top bag
*****Possible summer '01 mods*****
Dual Snorkle, Auburn Posi, Keyless Entry, Wonder Bar from my IROC, 4th gen seats, T/A tail lights
http://www.geocities.com/krt80/
[This message has been edited by Keith5 (edited April 07, 2001).]
Old Apr 8, 2001 | 03:17 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
That article refers to trouble codes, not TPS voltage, although the ALDL will pop a code for a faulty TPS, (21 or 22). To read the TPS voltage, it has to be done at the TPS harness, at the throttle body. Take two sewing needles and pierce the insulation of the top two wires of the TPS harness. Then clip the leads of a Digital Voltmeter to each needle. Turn your key to ON, and read the voltage. If it reads in the negative, just reverse the leads. It should be at .54v (+/- .075v) with the throttle blades completely closed, and should rise smoothly to just over 4.0v with the throttle all the way open (WOT). If it is jumpy or doesn't rise as you open the throttle, then the sensor is bad, just replace it.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
Old Apr 8, 2001 | 03:30 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yeah, the post was about Trouble Codes, its just that TPS also got mentioned. If you want to read TPS via the ALDL, you need a scantool.
To find out more about adjusting your TPS, go here: TPS
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Apr 8, 2001 | 05:04 PM
Car: 1985 Trans Am
My fault... I didn't even take into consideration the scan tool.. Thanks B.
Old Apr 8, 2001 | 06:10 PM
Keith5's Avatar
Car: C1500
I know how to set it at the TPS. I just wanted to know if two of the terminals of the ALDL could be used to get the voltage.
Old Apr 8, 2001 | 07:35 PM
Car: 1985 Trans Am
Nope, but like GM Tech said if you have a scanner then it would be able to read it for you through the ALDL.... otherwise you have to do it at the TPS harness.
BumpaD82
Feb 26, 2016 02:57 PM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
327IROC85
Sep 23, 2015 12:11 AM
eustodp
Sep 20, 2015 05:09 PM
