loud ticking at start up
Old Jun 29, 2004 | 12:47 AM
Shribe's Avatar
Car: 1988 IROC
Transmission: 700 R4
Axle/Gears: 2.77
have very recent issue of loud ticking that seems to go away after car 'warms up' I switched to 10 w30 for summer, could that be a factor? I have never heard lifter noise or valve noise but that is what i think it might be... what and how would i check and what would cause it, car is 89 L98 with 140K....
Old Jun 29, 2004 | 02:16 AM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
my car does the same thing..it's either a lifter or a rocker arm that's just a little too loose. use a stethescope and poke around the valve cover and see if you can hear it any better. i'm almost 100% sure that's what you problem is.
kev
Old Jun 29, 2004 | 09:09 AM
ljnowell's Avatar
sounds like a lifter. Quits when it pumps up with oil.
Old Jun 29, 2004 | 09:57 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Just readjust your valves. I f you don't know how, do a search. It is quite easy with the engine running. 30 minutes from start to finish, depending on how quick you can get your valve covers off.
chazman
Aug 28, 2018 03:25 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
redmaroz
Aug 16, 2015 11:40 PM
