Is there a four-core radiator?
Just curious if there's a four core radiator?
I know most radiators for the thirdgen camaro V8 are three cores, however I was curious if there was an aftermarket four core radiator that would fit in a thirdgen camaro.
Car: 82 camaro SC
You can get factory 4 core radiators from a junk yard. 3 row high efficiency works nearly as well.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
Guest
Posts: n/a
Yea, I have one. Its for sale too
AFAIK, there arent any 4 row radiators used stock in anything that would fit a thirdgen. IMO I think an aluminum is better, theres usually more fins, and its a bunch lighter than brass/copper. They are usually constructed better as well.
While looking, pay close attention to the actual size of the rows. A 4 row with 1/8" wide rows isnt going to hold a candle to a stock 1" wide aluminum radiator. Or then again, you could probably light the candle on the 4 row in that case because your car would be overheating.
Car: 88 Firebird WS6
Griffin sells dual 1" aluminums cheap (less than $200) and dual 1 1/4" for more. Either one will whoop a 4-core radiator, but you must do mods to fit it.
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
'88 Camaro RS 2.8L
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The f-body rad is a 19" x 31" GM style. To my knowledge there are no factory GM 4 core 19 x 31 rads available. I've seen wider ones but they won't fit between the frame rails. It may be possible to find a 19 x 31 Ford 4 core rad but the upper and lower rad hose ports won't line up.
There are many aftermarket 4 core rads that will fit. You could even ask your local rad shop to make you one.
A 4 core rad is also very heavy. For what it would cost to have one made, it would be cheaper to buy an aluminum rad.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
