I Dyno My SBC 400
Old Jul 5, 2004 | 08:17 AM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
I Dyno My SBC 400
Well after the last month of building anc changing parts I was able to get it on the dyno last week and i'm happy with the results for my weekend cruiser. We done the break-in for 20 minutes and did a total of 10 pulls. There is still a lot of potential left in the engine as it showed 20hp gain froma carburetor change. My intent was to build a 500hp/500tq motor for the street with 5% era allowed, but I can surpass both with a little more tuning and bigger carb. This engine was still pulling over 6200 rpms.
Here is 5 of the dyno sheets.
Dyno Sheets
Old Jul 5, 2004 | 08:38 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
From which carb to which carb did you pick up 20hp?
What is your compression? Why didn't you swap headers on the dyno to see what you could pick up?
Old Jul 5, 2004 | 09:46 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Nice numbers! I can see right off the bat that your setup acts totally different from mine. And I agree with you - more tuning and it should get even better. Lookin good!
BTW - I can barely see the sheets you posted (small) - what size carb you running? I know mine is jetted way higher than what you have yours....but I have a 650 DP....
Old Jul 5, 2004 | 11:09 AM
DTL504's Avatar
The Holley 750 Mec Sec DP 4779 pick up about 20hp/tq, I had the Holley 3310 Vac Sec, I'm thinking about going to a Demon 750.
I could not use my Hooker 2460 because they were hitting the bellhousing on the dyno stand. Now I need a long tubes Hooker 2055 anyone have some for sale!
The guy had already modified the bellhousing to clear my oil pan (Milodon 7Qt), so he would have had to do a lot more cutting on his bellhousing to get the shorties to work.
My compression is 10:48:1 and a quench of .041.
David
gixxer92
May 18, 2017 11:20 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
Bradsaundry
Oct 7, 2015 04:35 PM
