T-Top Latch Problems PLEASE HELP!
Car: 1989 Red T-Top Firebird, 1989 Iroc
Engine: 2.8L 173 C.I., 355
Transmission: Th700r4 Auto, Built TH700R4
I have an 89 firebird with t-tops, and one day i toop the top off to clean it and the plastic outer rod shot off and the spring came out I toop the plastic cover off and saw that where the c-clip attaches to the plastic rod broke in two. I have tried everything to glue it back together but nothing will hold it. Does anyone know where i can get a new one of these? All of the 3rd gens in the junk yards around here are picked over and there are no tops left on any of them. I really need a new one because I can lift the top about an inch up without it and it leaks bad cause it doesn't latch. PLEASE HELP! thanks alot!
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
GM might have the replacement clip. Or sometimes parts warehouses do.
Or you might try to make one yourself.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You could try a glass repair center or check with the junkyard. A lot of them remove the T-Tops and place them in a seperate location for resale later.
I know that I posted it in the wrong forum sry, btu it is not the clip I need its the plastic rod that goes over the metal rod which slides into the car to latch, but thanks for help, keep it comin
oh I forgot one thing, I tried to make one myself, doesn't look so great. its working for now and it keeps the rain out, but I would really like to get a replacement part if I can.
I don't know of any glass repair centers around here. I am open to other options of simply gettin this plastic rod though.
Car: 1987 Trans Am
Engine: tree-fiddy
well if you are in dire need, the junkyard I go to has atleast 10 t-top cars, and about 8 of them have all there tops. I found a t-top bag and t-top over head consol thingy today, it even had the flashlight, but the lens was shattered.
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
yes, but i bet you can fix the lens..... I too have a bunch of t-top cars at my local JY... there's a couple pairs of tops. if you need some, me and the doc should be able to help out.
I am gonna call around the yards today and see if any of the take the tops off and store them somewhere else, because I know they do that with windshields and stuff. But if not how much do you think I could get just that part for from one of you?
Car: 1987 Trans Am
Engine: tree-fiddy
If you give us a picture it would help, I've never disassembled a t-top, but if the part you need is small, I can get it and pocket it, i wouldn't normally do that, but the guy they have making up prices now sucks. He wanted $20 for some ****ty valve covers, I can get chrome ones from autozone for $30.
ok I can do that..I will take a picture in a few minutes do you just want a picture of the part I need?
Heres one picture, its not real great so I hope you get what you need out of it.
the first picture is the black rod I need, second is the t-tops on the car, and the last two show where the rod is in the t-top so you understand what it is.
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
