TO ALL THE 91 AND 92 Z'S
THIS MIGHT COME AS A WEIRD QUESTION BUT I WAS WONDERING......IS THERE ANY WAY TO MAKE THE HOOD "POWER" BLISTERS FUNCTIONAL? I WAS GOING TO BUY SOME AND WAS WONDERING IF THERE WAS ANY WAY TO DO THIS.
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Yes there is, unfortunatly I do not know how to do it. I have seen it done and they just cut the hole out and put some sort of screen in the hole to keep crap from falling inside of the hood. After talking with them though they all stated that they wished that they had not done it. It's to hard to keep the screens clean from debree. Hope that helps
'91 Z-28 5.7, SLP 1 3/4 headers, 4 inch Mufflex/Flowmaster cat back, gutted cats, Edelbrock intake, 8.5mm Jacob wires, MSD Blaster coil, S&W subframe setup, Jacob Pro Street Ignition, complete Kenwood system.
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
You could do it and try to use the air box from the older fourth-gen SS Camaro's with the functional ram air. You would still have to worry about water getting into the air filter. Good Luck.
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, SLP Clutch, Pro-5.0 Shifter, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
