possible fuel pump relay??
Old Apr 10, 2001 | 10:23 PM
302GT_killer's Avatar
i got a 90 305 TBI. it doesnt matter what temp it is, but it has a tendency to not want to start. it seems as if its only getting about half the fuel pressure it should, causing me to have to pump the accelerator ( i know its bad but i have to do that to start it). i usually get it to hold a steady idle after 2-5 minutes of sputtering. after that, it will idle fine at a light, but when i take off from a stop, i have to stab the accelerator to keep it from dying. it pulls really well above 2000 rpm but doesnt pull worth crap under 2000-i pulled a code 43 off the ecm which is a bad fuel pump relay but i dont really believe it. i thought a fuel pump relay only sent 12 volts to the pump at startup, or does it constantly send 12 volts? if it constantly sends voltage, why would the car die in gear and run poorly under 2000 rpm? thanks for the help.
Old Apr 10, 2001 | 10:48 PM
actually it was code 54 i pulled off the ecm for the pump relay-ignore the 43. i looked at a shop invoice from last fall and it was determined that 54 was an intermittent-i cant find anything on intermittent codes so what is this/what do i do?
Old Apr 10, 2001 | 11:45 PM
Vader's Avatar
Killer,
What IS the fuel pressure? It should be around 23 PSI at startup. Below 15PSI can be a problem.
Have you changed the filter lately?
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 10, 2001 | 11:58 PM
i replaced the filter about 7000 miles ago-shouldnt TBI systems run like a carb at about 10-12 PSI? i dont know what the pressure is since i dont have a gauge and id rather not spend 30-40 bucks on one unless i have to-im about 95% sure its low pressure, i just am not sure why
Old Apr 11, 2001 | 04:58 PM
now that im looking in my chiltons, i see that it cant be the relay-so what else would it be?
Old Apr 13, 2001 | 12:15 AM
i pulled a plug today and it was solid white
Old Apr 14, 2001 | 12:17 AM
anyone else? please??
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
