need expert help possibly
Old Jul 11, 2004 | 07:11 PM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
Ok i just did a cam and intake swap and now my tranny does not have drive or over drive...
when i first start it up it pulls reall good in drive then hits 2000 rpms and looses it then I can downshift into 2nd and 2nd gear works fine always..
b4 i go tearing the trans out i was wondering if i need to adjust something other than trans since i never had this problem till i did the cam and intake.... TBS maybe need adjusting? idk..
Its an 88 TBI auto with 700r4 and new lt1 cam and performer intake with tbi adapter plate
any help is greatly appreciated
Old Jul 11, 2004 | 07:15 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You should really adjust the TV cable, don't drive it untill you do, it will trash your tranny in acouple miles.
Old Jul 11, 2004 | 08:42 PM
dream02transam's Avatar
Car: 89 firebird
Engine: 2.8
Transmission: auto
Ok this might mean nothing since I dont know much about how the auto trans in an f-body is like (even though I have one now) I mostly had standard trannys.... But anyways if for some reason your tranny relies on vaccum to shift that could be your problem. My friend had a vaccum shift tranny in a mustang, he pulled the motor and rebuit it with a new cam and intake along with other things. Well his motor didnt pull enough vaccum to shift the tranny.... it worked fine in the first 2 gears but third had a problem especially if he floored it and higher RPMs I dont know how your tranny shifts ... if is a vaccum solienoid or not and I dont know how big a cam you put in but I do know that some real high perfomance race cams you wont have a lot of vaccum. The other guy is probally right it may just be the t.v. cable needs adjusting, but I thought I'd just add this just incase. By the way I think he fixed this by adding an accumulator (vaccum storage) to build up enough vaccum... got it through summit and eventually got a different tranny
Old Jul 11, 2004 | 11:28 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
The transmissions in 3rd gens did not use a vacuum signal, they use the TV cable to measure throttle.
Old Jul 12, 2004 | 12:04 AM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
trans no go
Yes I agree with Mr Leigh..
If you pulled your motor out to do this and accidently left the cable attached and strethed it out or just have it real bad out of adjustment you can be faced with the problems that you are having make sure the cable is still fully attached to the trans and the one bolt is still holding it in place there then check the adjustment at the intake.
Old Jul 12, 2004 | 11:46 AM
TransAmTBI's Avatar
Engine: 305 TBI
ok i'll def check the t.v or detent cable right? the adjustable one....
i did it with engine in car but greatly modified the throttle bracket and bent it around the gas lines s o hopefully this will fix something
LC2 TECH
Oct 13, 2015 11:53 PM
HoosierinWA
Oct 7, 2015 10:15 AM
djmarch
Oct 2, 2015 10:41 PM
mfp189
Sep 27, 2015 09:25 AM
