Gen VI BBC question
Old Jul 14, 2004 | 01:40 AM
Randel '86's Avatar
Car: '89 IROC-Z
Gen VI BBC question
OK, I am pretty sure you can, but some kid was trying to tell me that regular BBC heads and other parts are not compatible with the new Gen VI GM performance depot engines. Is this true or not?
Old Jul 14, 2004 | 07:39 AM
350camaro's Avatar
Mark IV heads will not go on a GEN VI, I think the water jackets are diffrent. Most after market heads will work with Mark IV, Gen V and GEN VI. The Gen VI also uses a diffrent oil pan and timing cover, I also read that a double roller timing chain will not fit under the GEN VI timing cover. Also you can't use flat tappet cams in the gen VI. I think there is some other stuff I forgot, there are some tech articles on the Gen VI blocks on the chevyhiperformance site, also check out chevelles.com forum lots of big block guys there.
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
