Need some help. Auto Xray has told me this:
Took some info on my Autoxray and noticed my fuel pump voltage is 13.3 and my battery voltage is 13.4. Usually the voltage is : battery=14.3 fuel pump=14.2
What would cause the voltage drop? Could it be the battery? The voltmeter is reading slightly lower and it looked like FP dropped a little on my gauge as well. I can also hear that the pitch of the fuel pump has changed
And while viewing "real time" mode on my Autoxray, I noticed Closed loop/ Open loop mode switches back and forth. Again, it never did this before either.
The oxygen sensor is new and is performing correctly. Any help or suggestions would be appreciated.
91 Formula 1LE 1 of 46
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 supercharger, Ford SVO 24#injectors, Crane AFPR,SLP airfoil, ported/polished plenum, March alt. pulley,Crane Gold 1.6rrs,MSD coil,MSD6AL (5400rpm limit),Holley 9mm wires,Ac delco R43ts plugs,custom chip,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,180* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
[This message has been edited by theformula (edited April 16, 2001).]
305 TPI 5speed
1LE/G92/WS6
