What is this thing???
Old Apr 16, 2001 | 09:18 PM
Tec21-CamaroLover's Avatar
I noticed today that at the back of my V6 MPFI Camaro Engine... Just behind (towards the distributor) the Intake Manifold Plenum There is a valve, it looks like an air valve for the tires but when you push the little pin in the middle down (the pin in the valve) gas comes out. The "valve" has threads on it as if something is supposed to be screwed on to it. Is there? Am I missing something in my engine???
'86 Camaro
2.8 MPFI
Old Apr 16, 2001 | 09:32 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
That's the Schrader valve. It's there so you can test the fuel pressure. That is where you can screw on a pressure gauge. The only thing that is supposed to be there is a plastic cap.
'91 Z-28 5.7, SLP 1 3/4 headers, 4 inch Mufflex/Flowmaster cat back, gutted cats, Edelbrock intake, 8.5mm Jacob wires, MSD Blaster coil, S&W subframe setup, Jacob Pro Street Ignition, complete Kenwood system.
morrow
Jan 13, 2024 12:29 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
TheExaminer
Aug 19, 2015 10:07 PM
Bob88GTA
Aug 18, 2015 03:31 PM
