radiator?
Old Apr 18, 2001 | 01:20 AM
v6-3.1's Avatar
radiator?
I have a 1990 camaro rs 3.1 V6. I was wondering if it would be good to change the radiator for a V8 radiator with dual fans (not sure if they all come with dual fans).
would it cool better?
would it cool quicker?
Old Apr 18, 2001 | 06:06 AM
Mach5's Avatar
Unless you made some serious modifcations to your engine then it would be best to stay with the 3.1 radiator becuase the engine needs the heat to function effieciently. If you are having cooling problems then you should check your system and find what the problem is. The V8 radiator would cool the engine faster once the thermostat opened. THe dual fans are also not necessary.
sheachopper
Jul 31, 2019 11:27 AM
lanceflame44
Sep 25, 2015 12:28 PM
