what the hell happed
Old Apr 21, 2001 | 02:53 PM
88rscaamaro's Avatar
i started my motor today and this foam looking stuff came spill out of the breather and the oil dip stick tube what is it. I know it cant be good
1988 Camaro RS T-Tops white. Was 2.8 now a mean 406 sbc
(mods)
750 Edelbrock carb
Performer RPM intake
Comp cams Magnum @.50 230-230 lift 480-480
Flowtech 1 3/4 headders with glasspacks for true duals and thats it for now
E.T. 1/4=?
will post when race season starts
2 10' Kicker comps
Kicker 500w amp
Pioneer head unit
2 Jensen 3-way 6x9
along the road
perfomer RPM heads?
NOS
pistons, rods
roller rockers
4.10 rear with posi
91-92 ground effects
Old Apr 21, 2001 | 03:43 PM
and now i have water it looks like droping out off the rear main?
Old Apr 21, 2001 | 04:33 PM
CamaroZ_85's Avatar
well if the foam looks liek chocolate milk then you have water in the oil, which isnt cool. a few things that would cause that are cracks in the head/block, bad head gasket, bad intake gasket, or some other internal breakage. good luck!
PS dont run the motor like that, cause if your bearings arent already trashed you definately will kill them
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
[This message has been edited by CamaroZ_85 (edited April 21, 2001).]
Old Apr 21, 2001 | 08:05 PM
Mark W. Winning's Avatar
If the motor ran at all, the bearings are no good. This happened to me last year. Motor had only a few minutes (3-4) of run time. I got a pin hole in the block. Water came out the dipstick tube! When I broke the motor down, the bearings were all ready "streaked". I am sure that if I had just fixed the problem and ran the motor again, the bearings would have failed in short order.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
FormulasOnly
Jul 23, 2018 08:47 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
92camaro350cci
Oct 14, 2015 09:29 AM
aaron7
Sep 30, 2015 09:15 AM
dimented24x7
Sep 6, 2015 03:51 PM
