distributor
Car: 1985 Camaro Z 28
Engine: 305 LG4
distributor
I cant get my distributor to sit flush when i put it back in, there is a small gap between the block and the collar on the distributor. I find that its only going in one way but wont mate all the way, any ideas?
Transmission: 4L80E/4L80E
The distributor drives the oil pump. The oil pump shaft has a slot in the top to mate with the distributor shaft.
Stick a large screwdriver down the hole (when the distributor is out, of course), turn the oil pump shaft slightly, try again. Repeat until the distributor drops into place.
Engine: 305 LG4
Ok i got it in, didnt have to do what you guys said I should do, anyhow i didnt mark it when i took it out as I saw 1 mark already, the rotar wasnt matched with the base though. Anyhow, it only went in either 2 ways, far left or far right, no in between, im guessing that i will need my timing adjusted at the shop.
what you need to do is crank the engine over to TDC on compression stroke for #1, and then restab the distributor with the rotor at #1 plug terminal on the dist. cap. If you dont, it wont run. At least not very good.
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Damon
Sep 26, 2015 04:29 PM
