Too much oil cause heatin up???
Old Apr 23, 2001 | 03:45 AM
uno's Avatar
uno
Well I haven't changed the oil since I got my 89 RS but i have had some smoking and temperature overheating, Can too much oil cause this? Because i have almost 3 quarts too much in my motor....I am pretty sure that's what this is?
what do you guys think?
1989 RS Olds V8
400 tranny
Just underway..
1995 Red T-Top Camaro
3.73 Gear
Flomaster Cat Back
Accel 8.8 Wires
Bosch Platinum Plugs
K&N F.I.P.K.
Killer Cerwin Vega Sound System
Sony Xplode Head Unit
Old Apr 23, 2001 | 10:21 AM
camaro6spd's Avatar
change your oil and put the right amount in it. The rods can start to hit the oil and make it foam then you start sucking up an oil-air mix and parts don't get lubed right. It is almost as bad as not enough oil. Change it and put the right amount in or at least drain the oil and take out but for but for 15 dollars go out and get 5qts or whatever of decent oil. It is not gonna kill you.
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
