Please help me out here!!
Old Apr 19, 2001 | 02:39 PM
MR. JORDAN's Avatar
After replacing the hoses from my heater core to my stat and intake. I am leaking antifreeze into the passenger side of the interior, just under the dash?? In your opinion, what woud cause this??? thanks in advance!!!!!!!
Old Apr 19, 2001 | 02:46 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You need to replace the heater core. I have heard a lot of people say it is a pain, that they have to remove the dash, all I had to do was remove a black panel though.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
UNDERDRIVE PULLEY
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Old Apr 19, 2001 | 02:48 PM
89BlwnRs's Avatar
I second Mark. I had the same problem and my heater core had busted.
Jason
Old Apr 19, 2001 | 03:30 PM
82RECAROTA's Avatar
Old Apr 19, 2001 | 03:38 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
Remove the hoses from the heater core... if the old ones were hard to remove, then you might have some of the old hose material still on the nipple (or whatever you would call it), and you just can't see it. I had the same problem a couple months ago, thought it was one of the freeze plugs on the back of the block. Thank God I checked the connections on the hoses first and found a chunk stuck to the inside of the hose preventing a tight seal no matter how tight the clamps were. Just a thought......
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
Old Apr 20, 2001 | 08:09 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
He said 'nipple' ehehehhe
Just kiddin....
Possibly the core was pretty corroded and if you didn't use a razor to cut the old hose off and resorted to manhandling it off, you may have cracked the 'nipple' where it enters the core.
They are a pia!
Old Apr 20, 2001 | 11:23 AM
Mark W. Winning's Avatar
My heater core did the same thing. Worked fine, I swapped the V6 to a V8 and the heater core leaked into the car. I later found the the heater core had cracked. Probably from the stress of taking the old hoses off.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old Apr 23, 2001 | 05:58 AM
MR. JORDAN's Avatar
Well you guy were right.. The core was busted. Why GM would put screws way up there is beyond me though Oh well problem fixed..Thanks a lot guys!!!!!
Old Apr 23, 2001 | 01:24 PM
MR. JORDAN's Avatar
Oh and thanks Again!!!!!!!
Thank you!!!!!
