blueprinting question
Old Aug 2, 2004 | 02:53 AM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
since pistons are tapered slightly, when measuring piston-to-cylinder wall clearance, do you measure from the base of the skirt or what?
Old Aug 2, 2004 | 04:33 AM
ede's Avatar
ede
i use a long feeler gage full heigth of the piston.
Old Aug 2, 2004 | 05:58 AM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Measurements are taken 90 degrees from the wrist pin.
Old Aug 2, 2004 | 08:18 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Most of them will speicfy where you're supposed to measure.... so many thousandths below the ring landsor the top. Without the specific spec that the mfr uses for their pistons, it's mostly just a guess. But most of them are measured at something like ¼ - ½" below the ring lands, and perpendicular to the pin as mentioned.
Old Aug 2, 2004 | 07:53 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
This is where KB says to measure their pistons.
I always measure all around the piston with a micrometer and find the biggest point, then set up a dial bore gage to check the cylinder size. Thats the correct way to do it, but not everyone has the tools or skills to do it that way.
Old Aug 3, 2004 | 02:13 AM
cormyr's Avatar
Engine: 383 miniram
ok i found the info from probe industries. right on dart, thats exactly where probe says to measure, and yes, at 90 degrees perpendicular to pin.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
