flywheel
Old Aug 4, 2004 | 03:30 PM
86s10's Avatar
flywheel
hey, i need to know how to put on the flywheel properly. its a weighted flywheel, what position do i put the crank in, and how do i align the flywheel so that the weight is balanced properly? thanks
Old Aug 4, 2004 | 10:54 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
there should be only 1 way all the flywheel bolt holes will line up on the crankshaft bolt holes.
Old Aug 5, 2004 | 04:45 AM
ede's Avatar
ede
it's dowelled. there is no way you can get it wrong.
Old Aug 5, 2004 | 11:28 AM
86s10's Avatar
Ok Thanks. thats what i thought, I couldnt tell because the engine is on a stand, but just wanted to hear it from someone else.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
