383 Buildup....need suggestions
Old Apr 24, 2001 | 07:25 PM
Bandit TA's Avatar
Hello,
I've recently decided to build a non-emissions legal 383 stroker from scratch and need a few suggestions on what you guys think. This engine will run on 92 octane and be streetable, and hoping to make 500hp.
Here's what I've come up with:
-Scat 3.75 Crank
-Forged Rods 5.7in w/ARP rod bolts
-Forged Pistons (9.75:1 CR) w/ moly rings
-World Sportsman II heads,64cc, 2.02/1.60, 3 angle valve job
-Cam with 236/242 duration at .05 inches
-1.6:1 rockers
-Edlebrock Performer RPM intake
-Holly Double pumper, 750 cfm
-Edelbrock Water Pump
-Flex Fan
-True Dual exhaust w/ turbo mufflers and headers
-HEI Distributor (50,000 volts)
-Turbo 350 tranny built to high torque specs
Now, here are my questions:
1) Does those sound streetable and able to run on 92 octane no prob?
2) What size torque converter would work best with this setup?
3) Is the compression ratio alright, should it be higher/lower?
4)For the cam, should the Lobe seperation angle be 110 or 114 or what? and does the cam sound to high of a lift, somewhat rough idel is ok?
5)What size gears should i run in the rear, remember street use mostly?
6)And for the carb, double pumper....mechanical or vacume secondaries?
Or should i just get 2 different carbs, one for street and one for track? If so which?
If you have any other input please let me know, just no nitrous or blowers pleale
Thanks a lot guys, any help is much apperciated
Old Apr 24, 2001 | 07:49 PM
burnoutrpm's Avatar
this combo should be alot more "streetable" than the one in my sig my compression is just ****ing insane..for the street!! id say a 2500rpm stall should be adequate. the compression is just fine doesnt need to be altered. if you like the rumblely idle(as i do)...the more the better!! the lift is also fine as long as you acheive at least .100thnds on the intake and exhaust valves. if you r using "puke port rejection"..tuned port, then, use a 112 or 114 lsa. if only if you have a carb or custom burned chip is 110 ok. id run a 3.42 rear gear or possibly 3.73 if you have a 700r4. as for a carb i wont dis or slam holley,but, for holley get a 4150 double pumper carb about a 750 should be quite enough.(may have to re-jet the 750!) always always..no matter what anyone says USE MECHANICAL SECONDARIES!!! and only get 1 carb well tuned and you shouldnt have a problem running this on the street daily! ok i wont suggest juice.....but it would make you grin..ear to ear!!
89 firebird formula
360 11.0:1compression (350 .060 over)/fully balnced and blueprinted
comp cams xe262 cam
performer rpm intake/port matched to heads
#1407edlebrock 750
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner/cnc pocket ported
msd 6al/msd8.5 super condutor wires
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
griffin daul1" core rad.cutom fabrication to fit(but no cutting )
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
[This message has been edited by burnoutrpm (edited April 24, 2001).]
Old Apr 25, 2001 | 05:04 PM
Polecat's Avatar
burnout, very well said. I am running 10.7:1 on the street, uses 93 octane, and I have to back the inital down some, but when 3000 rpms' come around....watch out!
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with Hughes 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
83RDRACR
Mar 26, 2016 08:13 PM
Nervous2
Oct 8, 2015 10:53 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
JSDaddy189
Sep 26, 2015 03:50 PM
