R&R steering column 82 into 89
Old Aug 11, 2004 | 12:45 PM
Buck268's Avatar
I'm about to be swapping steering columns from an 82 parts Firebird S/E into a 89 Formula, and was hoping for some assistance.
First, I'm unfamilar with how to remove these things. I've heard its fairly easy, but I'm having trouble seeing how to do it (I'm no moron either, installed a posi in my car, soon to be swapping 3.73's in her too).
Also, the parts car is a non-VATS car, while the Formula has VATS. Could somebody please PM me with how to bypass thye VATS? I think I know, but would like verification (and I don't think this is the type of info that should be floating around).
Thanks for any help
Old Aug 11, 2004 | 01:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Exactly why are you doing this?
The electron flowing parts will be different, but should swap over from one to the other. I think. Maybe not. I know they did 82-86, but you're talking even a bigger spread.
VATS shouldn't be a problem. If part A above in fact works, that is. Otherwise, we won't discuss bypassing VATS on this forum, thank you very much.
Old Aug 12, 2004 | 12:10 PM
Buck268's Avatar
Alright, I'll just have to figure out how on my own
And I'm swapping them because his column in the 89 is toast, can rotate in like a 4 or 6" circle...
Old Aug 12, 2004 | 12:22 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
you can retain your vats ignition cylinder, I did. You will need to make the hole bigger for the ignition cylinder to fit into though, not to hard. I swapped a column from a 82 bird into my 89 maro. You will most likely need to swap the turn signal lever as well, not too hard to do though.
Old Aug 12, 2004 | 12:25 PM
89RsPower!'s Avatar
oh actually removing the column is easy, first remove the underdash cover if its still there, remove anything directly under the column basically, then theres 3 bolts holding it to the firewall, and a couple of bolts holding it under the dash. You will also need to unbolt it under the hood where its bolts up to the other shaft, theres one bolt holding it there. Then unplug all your harnesses and shes out. If you find yourself swapping turn signal levers they are fairly easy to pull through the column with a bent coat hanger wrapped around the end of the wiring harness.
Old Aug 12, 2004 | 04:45 PM
five7kid's Avatar
Tighten up the tilt pivot bolts. Happens a lot, much easier to fix than swap.
Old Aug 12, 2004 | 08:40 PM
Buck268's Avatar
hmm, thanks for the great info. My Camaro didnt have tilt, so this is the first time I've had to worry about it, I'll tell him to chekc the bolts, hopefully thats it but if it aint, then I guess I'll get to put 89RS's advice to use!
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
