type of coolant for alum heads..
Old Aug 13, 2004 | 04:30 PM
JeffC1500TBI's Avatar
I was told that the green gm coolant is not very good on aluminum heads. someone suggested using the toyota coolant. anyone have opinions on this?
thanks
Old Aug 15, 2004 | 09:43 AM
no input on this? does everyone just use the green gm stuff with alum heads?
Old Aug 15, 2004 | 10:02 AM
Vader's Avatar
O.K. You got me. What is "Toyota coolant"? Rìce Krispies in milk? Honestly, I don't know. I use DexCool in everything I have, including aluminum/iron engines and the old '86, with no problems.
Old Aug 15, 2004 | 12:16 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The green stuff is fine. So is Dexcool, although it strongly tends to find ever leak, no matter how microscopic; it will even seep through places like the paper gasket on the back of the water pump, most thermostat gaskets, etc. Personally I'd use the regular green stuff if the motor isn't completely outfitted EVERYWHERE with better gaskets than the usual paper ones.
Old Aug 15, 2004 | 01:22 PM
StangKiller's Avatar
I've heard good things about the Toyota coolant, The 'Red' Toyota coolant controls corrosion by using inhibited oxalic acid to keep the rust from ever forming.
The 'Green' coolant controls the corrosion by 'painting' the inside of the engine's metal with silicone particles. Everytime the engine heats up and cools down some of the silicone paint particles flake off - which means you need to replenish the silicone additive every 2-3 years.
I"ve never used it but was going to try it next time I built a new engine.
Old Aug 15, 2004 | 07:40 PM
I guess I'll just stick with the green gm stuff ..
sheachopper
Jul 31, 2019 11:27 AM
bjpotter
Oct 4, 2015 07:48 PM
