can you take off your AC and smog pump and keep the serpentine belt ??
Old Apr 30, 2001 | 08:46 PM
91camaroRS's Avatar
topic explains it
350 bored 30 over ..882 casting heads ..comp cam..hooker headers.. 700r4 corvette servo .. 3.73 and SLP posi no hood on the car , holley 750 CFM, performer RPM intake.. and umm couple other things here and there
Old Apr 30, 2001 | 09:07 PM
Justa6's Avatar
Your gonna have to get a shorter serpentine belt. What size I dont know, it'll be trial and error situation getting the right size.
Old Apr 30, 2001 | 11:10 PM
91camaroRS's Avatar
the problem is the belt loops over the AC and alternator so the tensioner can push on it... so if i remove the AC the belt would not go on right nomatter what length it is
Old Apr 30, 2001 | 11:27 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
You can get an A/C delete pulley, and from what I've been told, you can also get a smog pump delete pulley (someone said it was the same part number) from your local Chevy performance parts dealer.
Old May 1, 2001 | 12:23 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
just get ar eally short belt and have it loop over the tensioner pulley right off the water pump and have it go back to the alternator
purty simple kids
Old May 1, 2001 | 01:22 AM
idrag2's Avatar
Well the problem you will have is the tensioner. You will need to get a delete pully for the AC but the smog pump can be thrown away. You can still use your same belt without the smog pump. Run the belt as the following,,,,,
Run it under the crank, from the crank take a stright shot at the A\C go over the A\C then under the tensioner, over the Alt. then under the power steering and around the water pump.
This is how I run mine and it works fine using the same belt. There is a digaram of it somewhere on this sight that I saw when I first came to it but I can't remember where its at??? You will also notice a major power increase. Good luck
I DRAG 2
Old May 1, 2001 | 07:14 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
I ditched the smog pump and got an idler pulley off of a 2.8 camaro and an alternator braket off an 80 monte carlo, with a little cobbling together and some hacking on it with a grinder...
It doesn't look as good as the 1LE delete gizmo, but i'm $90 richer. I used twine to wrap around the pulleys while my buddy held the tensioner all the way. I snugged the twine and removed it, took it to autozone and got a 6-rib belt that the twine fit inside of. Nailed it first time.
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
italiano67
Dec 11, 2016 09:21 AM
mustangdmurder
Aug 21, 2015 07:17 PM
jahblah
Aug 12, 2015 05:54 PM
