What causes back-firing?
Old Apr 30, 2001 | 11:01 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
My '68 Camaro back fires when very once in a while and its pissing me off. What causes backfires?
'82 Camaro SC - totalled
'80 Camaro SC - sold
'83 Camaro Z28 - sold
'85 Camaro Z28 - sold
'94 Camaro SC - stolen
'68 Camaro - for sale
'91 Camaro RS - my new baby
Old May 1, 2001 | 06:56 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Backfires out the exhaust (after fire) indicate unburnt fuel, reigniting in the hot muffler/pipes.
Causes are many, retarded, incorrect timing (valve or ignition) rich mixture (usually only afterfires on acceleration though)
back fire through the intake is caused by incorrect mixture too, usually lean, and or incorrect valve and ignition timing as well.
Keep in mind that incorrect timing doesn't necissarily mean you base timing is off, but that the cylinder could be firing from a crossed plug wire, cross arcing from wires, etc.
Header/exhaust leaks are good for after fires as well, drawing in air to ignite the hot exhaust gases in the pipes.
There's probably a several other things, but generally fuel and ignition are the first things to look at.
BadDog
Sep 12, 2011 04:28 PM
beaner67
Carburetors
Aug 17, 2009 02:31 PM
BWilcox
35
Mar 30, 2009 07:49 PM
swerve
Jun 27, 2007 12:51 AM
