hmmm...gear drive issues, not the normal ones
Old Aug 23, 2004 | 12:11 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
ok so i supposedly bought a pete jackson quiet drive and did all my research before so it should work on the new engine. but (now keep in mind ive never built an engine before) i was messing around just now and couldnt get the crank gear over the crank!!!!! is there a difference in 350 (or 305) and 400 crank diameters where the crank gear would go????? apparently this works just fine on 350 engines (as it was on one before) but unless you really just have to use a BFH and pound that thing on it isnt fitting!!!
Old Aug 23, 2004 | 01:34 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
No difference in the diameter of the crank snout. Grab a mic and measure the top and bottem of the crank snout, see if it balloned out a bit at the top, BFH damage.
Old Aug 23, 2004 | 01:38 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
ok illget my dial caliper and measure.......but it sounds like (since you need a gear puller to get one off) they dont go on very easily.....BFH time!!
Old Aug 23, 2004 | 01:46 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Don't force it. I used a rubber mallet, not my BFH.
Old Aug 23, 2004 | 01:55 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
always there for me stekman........<----------good guy to talk to BTW
specialized
Jun 18, 2022 09:26 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
mustangman65_79
Aug 8, 2015 12:07 PM
