Instructions anywhere for A/C removal ?
Old May 2, 2001 | 01:49 AM
jaretz28's Avatar
I have a 1983 Z28. I have windows that unroll and t-tops that come off. So I want my A/C out ! It is too difficult to change spark plugs and such cause the A/C is always in the way.
Anyone know if it is dangerous to do this in my garage? Anyone done this before? How about where I can get detailed instructions on how to do this? Thanks
Old May 2, 2001 | 08:43 AM
GTARob's Avatar
The spark plugs seem kind of easy to me. You can get 1,3,5,7 easily and if you take off the AIR bypass valve(2 bolts)You can get to 2 and 4 from up top. To get to numbers 6 and 8 just jack up the car and get them from underneath. Having stock exhaust manifolds would make that a little harder but all it takes is a 3 inch extension for the two from the bottom. I'd say staying cool is worth having to spend all of thirty minutes doing a tune up every 5,000 miles. Then again I'm in Texas.
1989 GTA TRANS AM
Was a TPI 305 & t-5 car.
Is now 383 stroker w/ the same T-5
World products Sportsman II heads(64cc fast burns). Lunati pistons@10.5:1 and 452/462/112* camshaft. Eagle crank and 6 inch rods. Ported/polished/port matched stock TPI intake. T-5 on a suicide mission.
Old May 2, 2001 | 09:29 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I was able to lift my (and a friend's) a/c system out completely without opening any fittings; if you search this message board (or the "archives" board?), you should be able to find my old message about it.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old May 2, 2001 | 12:09 PM
jaretz28's Avatar
It's actually not just spark plugs. I cannot get my header off the passenger side. Too many things in the way. Why take off the headers? Cause they are always rusting through the paint because of the high humidity here. So I spend an afternoon grinding off the rust, repainting and baking them suspended over the BBQ ! I cannot afford a ceramic coating so please don't even suggest it.
my86bird
Oct 23, 2015 12:20 PM
TheExaminer
Sep 6, 2015 11:40 PM
RyanJB
Sep 2, 2015 01:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Night rider327
Sep 2, 2015 04:18 AM
