Must be 3rdGen breakdown day!
Old May 1, 2001 | 06:55 PM
89RustangRemover's Avatar
just ran into a problem with my '92 RS. after changing the ignition module on it, it started blowing the ACC fuse. the one for the horn, rear hatch, and dome light. didn't do it before. i thought it was just the occasional blown fuse until i popped 2 fuses consecutively before putting them all the way in! i even put in a 30 amp (original rating is 20) and it blew that one after a while. i checked all the wiring that i messed with that day and everything is in order. what could it be? is there a test of some sort to find out what is drawing too much power? let me know ASAP as I can't do without my horn because of the many idiotic drivers here in tx that got their license in a crackerjack box. thanks in advance for any help provided.
"WARNING: Objects in mirror are about to disappear VERY quickly!"
Old May 1, 2001 | 08:23 PM
ede's Avatar
ede
does everything work? can you make sure all the accesoreys work? there is a short locator tool you can buy to help pin point the location of a short and then investigate more to locate the source of the short.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 1, 2001 | 11:58 PM
Everything works as long as there is a fuse in there. like when i put the 30 amp. but then it blew it too.
Old May 2, 2001 | 02:17 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Do you keep change in your ashtray? If so, check for a penny that fell into the cigarette lighter.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old May 2, 2001 | 10:57 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Just unplug the Ciggarette lighter and see If that makes a difference. it did with mine.
91 Z28 5.7l Camaro
T-56,McLeod Street Clutch, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
Old May 3, 2001 | 12:01 AM
hey guys i appreciate all your help! turns out the the lighter was getting stuck and not popping out after getting warmed up. just have to replace the lighter. maybe not since i don't smoke! but thanks again! i'm really starting to like it here!
RedLeader289
May 28, 2019 01:47 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
