Confused about Lobe Separation Angle
Old May 2, 2001 | 12:06 PM
wiggy'sIROC's Avatar
Car: 1986 IROC
Engine: 305 going to 355
What effect does this have on my motor or on my computer? I am bulding a 355 with Vortec heads. Currently, the car has an LG4 in it and I will be using the CC carb, distributer, and the rest of the computer stuff on the 355. I looked at Comp Cams about the Extreme Energy 262 and 268 grinds and found out that they make two of each (one for TPI and one for carb) and the only real difference was that the TPI cam uses 114 LSA and the carb one uses 110 LSA. I don't know which one of which grind will work with the computer. I want to keep the computer stuff hooked up due to my being military and I never know when I will have to move. Thanks guys!
Mark
1986 IROC LG4 "Bone Stock" (for now)
Old May 2, 2001 | 12:14 PM
Bort62's Avatar
less LSA means more overlap.
More overlap Means less Vaccum, and Higher emissions.
Sooo.....
Since the Computer on the TPI cars uses vaccum To monitor various things, More overlap causeing less vaccum will throw it out of Whack.
Get the Non TPI Cam, Your LG4 ECM dosent care. ( and Even if It did, Not alot it can Do about it. )
And get the 268, The 262 Is Mild In My stock 305, with 50 more cubes, you want that extra duration and lift
And How exactly Do you plan To use Vortech heads with the CCC carb ?
Either the redrilled heads, Or does eddie Make a performer RPM Vortech Spreadbore, I didnt think so...
Im Not bein a smartass, Just wondering )
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old May 2, 2001 | 12:23 PM
Car: 1986 IROC
I was going to use the Performer Vortec P/N 2116, it is spreadbore. They now have Performer Air-Gap, but I don't know if that will fit under the hood.
Mark
[This message has been edited by wiggy'sIROC (edited May 02, 2001).]
Old May 2, 2001 | 08:51 PM
ede's Avatar
ede
comp and lunati both have great cam tech in their catalogs, and most likely their web sites. if you're messing with cams you should get one or both.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 2, 2001 | 08:54 PM
Bort62's Avatar
Cool Wigg, Didnt know they had em out
Sure opens up possibiltys, and No the Air gapper wont Fit, performer is withing 1/2 inch of hood with hte stock air cleaner.
Old May 3, 2001 | 08:56 AM
Car: 1986 IROC
Thanks for the help! I want this car to (I)ROC!
[This message has been edited by wiggy'sIROC (edited May 03, 2001).]
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Jorlain
Oct 8, 2015 01:57 AM
skinny z
Oct 5, 2015 06:23 PM
mfp189
Sep 27, 2015 09:25 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
