CAR IS SCREWED!!! need help ASAP!!
Old May 4, 2001 | 12:20 AM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
I just put my headers on got a 2 1/2 y pipe with no cats, to fit with my 3 inch borla exhaust. but when I put my headers on I decided to port my base. so everything came off. now the car runs like crap. has a hard time starting and when it does It stumbles misses and backfires. It has an erratic Idle. when I start driving It jerks the car back and forth violently. I tryed to adjust the timing (its WAY off) but when dash starts to come close to the Timing tab the car runs worse. what could this be?? someone told me the distributer is a tooth off. but which way is it off? clock wise one tooth or counter clock wise. I checked the codes and came up with 23 33 34 and 42.
Would all this be associated with the timing or what?
91 Z28 5.7l Camaro
T-56,McLeod Street Clutch, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
Old May 4, 2001 | 07:37 AM
ede's Avatar
ede
are you setting the timing with the est unplugged? it sounds like timing problem to me. if you are checking the timing correctly i'd go back and find TDC, set the rotor to #1 and recheck the wires are going ot the right plugs.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
1992 Trans Am
May 10, 2023 07:19 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
9192camaro
16
Feb 3, 2019 12:21 AM
camaro71633
Sep 1, 2015 10:24 AM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
