How Much HP
Old Sep 1, 2004 | 07:53 PM
BigD'sTransAm's Avatar
Car: 1986 Trans Am
Engine: 305ci Carb.
How Much HP
I have an 1986 Trans Am with the 305ci carbureted and was wanting to add:
1. Edelbrock Performer intake manifold
2. Speed Demon carburetor 650 CFM, Electric Choke
3. Mr. Gasket Carb Spacer
4. FlowTech Maximum Performance Headers shorty-style, 1 1/2 in. primary tubes 2 1/2 in. collectors
5. FlowTech Afterburner Mufflers
6. FlowTech Universal Off-Road X-Pipes
7. K&N X-Stream Air Flow Top (500 plus cfm of air flow)
About how much horsepower do you think that I will be making?
Old Sep 1, 2004 | 07:56 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Not as much as you think, without a cam or head change.
Old Sep 1, 2004 | 08:02 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Less then 200hp
Old Sep 1, 2004 | 10:49 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
1 5/8 headers and a full 3'' exhaust is where you want to start. Then you need to have your heads milled to achieve at least 9:3:1 compression, get an XE256 cam, performer(Performer RPM is much better)intake, and a 650 holley dp(speed demons are rated different and a 650 is prob. to much for your engine). Then you will at least make 260hp or so. The real restriction on the Lg4 itself is the cam and compression remember that. Good Luck.
Old Sep 1, 2004 | 11:48 PM
Cameron's Avatar
Car: 1985 Z28
Transmission: 700-R4
I read a lot of car magazines (i mean a lot i have every car craft since 91) and i'd say under 100hp be close to that tops...
Old Sep 2, 2004 | 07:14 AM
Car: 1986 Trans Am
Engine: 305ci Carb.
Thanks Guys
