Oxygen Sensor
Old May 3, 2001 | 07:50 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
Oxygen Sensor
my camaro jsut threw a code 45 (or whatever a rich oxygen sensor is), so i was wondering if i could just disconnect the oxygen sensor to get a better air/fuel ratio, or do i have to get a new one?
Old May 3, 2001 | 08:07 PM
coach's Avatar
Just because you get a trouble code doesn't mean that the sensor is bad. It can be the connection that is bad. The wire from the sensor may be damaged. But it may very well be that the O2 sensor is bad. If it's running rich, the car may not accelerate off the line as well as before. But it could also cause the car to have a little more top end power (that is, before the problems associated with a rich fuel mixture start showing up).
As long as the car's computer is running the show I wouldn't disconnect any of the sensors. The O2 sensor plays a very important role in how well your vehicle runs, fuel efficiency, longevity of spark plugs and catalytic converter(s). The computer is constantly looking at the input from that sensor and is constantly making adjustments to the fuel mixture. That only applies to when the car has gotten up to operating temperature; before that has happened the fuel mixture is preset by what the computer has programmed into it.
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Get a new one and change it. The computer relies heavily on the O2 sensor for its fuel calculations. Without it, you'll get horrible gas mileage and the car will run rough.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old May 3, 2001 | 08:16 PM
Vader's Avatar
87,
The problem you are experiencing sounds less like a failed oxygen sensor and more like an actual rich condition. The typical failure mode for an oxygen sensor involves a constantly weaker signal from the sensor, indicating a lean condition but causing the ECM to enrich the mixture, causing a rich condition. The O2 sensor detect a lean condition, and would set a '44' instead of a '45'.
What engine/fuel system/mods do you have?
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old May 3, 2001 | 08:45 PM
ChevyGuy87's Avatar
Engine: 4.0
it's a stock 2.8 with MPFI, the only thing i put on was 8.5 MM wires and Bosch Platinum +4 plugs
Old May 3, 2001 | 08:56 PM
ChevyGuy87's Avatar
Engine: 4.0
also, the timing is supposed to be at 10 BTDC, and i have it at around 14-16. could that be causing a rich condition?
Old May 4, 2001 | 01:41 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Amen to that, Coach... my oxy sensor connector cooked on my exhaust once... that wire is now tied -far- out of the way!
The 14-16 might be too far advanced for power/mileage/emissions, but I doubt it would throw you a code 45.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
