Cylinder Heads
Car: 84 berlinetta
Transmission: auto
Cylinder Heads
some guy told me to use 350 heads on my 305, arent they too large and would cause the engine to bog? what would be a good size to switch with? 307, 327? if not when i change my valve seals is there any thing i can do to impove performance? ie. rockers or push rods?
thanks for any help
(limited budget right now)
thanks for any help
some guy might be right but it would depend on the heads and waht you have as well as what you're trying to do. a little more info would go a long way, but a WAG is that it wouldn't be a good idea.
Transmission: 4L80E/4L80E
Exhaust.
Until you do that, no amount of head pounding is going to make a lick of difference.
Chuck84TA
Jul 15, 2016 09:05 PM
NinjaNife
Aug 23, 2015 11:49 AM
