Rocker Arm Torque Specs
Car: 04 GTO
Transmission: M12 T56
You don't torque rocker arms, you adjust them. 1/2 to 3/4 turn from 0 lash.
How to get there:
1- Set the engine to #1 firing postiion (balancer at 0 mark, amke sure you are at #1 not #6 firing by making sure the lifters from #1 are al the way in their bores, 6 should be moving.)
#2- Adjust both valves for #1
#3- rotate engine 90' and repeat for #8
#4- rotate 90' and do #4, etc through the firing order (18436572)
...ed
How to get there:
...ed
Car: '89 GTA
Engine: ZZ6TPI
Usually one turn past zero lash. Make sure that cylinder in on the compression stroke and while turning the pushrod between your thumb and forefinger. Tighten the rocker arm nut until you feel resistance when you turn the pushrod. Turn the rocker arm nut one full turn past that. Do the other valve for that cylinder, then move on to the next cylinder.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Magnaflow cat-back,
K&N open element,
Car: 04 GTO
oops, guess i should have told you how to 'adjust' them too. What you do is spin the rocker nuts down till there is no play n the pushrod. You can check this by spinning it, or moving it up and and down. This is the 0 lash point, and until you screw it up once, you probably will get this wrong.
Once you hit 0 lash, then you wind down another 1/2 -3/4 turn to set the lifter preload.
...ed
...ed
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
