Steering wheel noise?
Old Sep 7, 2004 | 04:27 PM
ThUnDeR2005's Avatar
Car: 1990 Camaro "RS"
Engine: 355 TPI
Axle/Gears: 3.23 LSD
Hey guys Just wondering what may be the cause of this screeching noise that i get when I try turning the steering wheel when the car isn't moving (but on). LIke when I tried to adjust to park, it made this loud screeching noise that sounded almost like a loose belt. Only happens when steering though.
Lil Help?
Old Sep 7, 2004 | 04:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Hmmmm......
Look at the belt maybe?
Old Sep 7, 2004 | 04:43 PM
Engine: 355 TPI
I checked them over a bit ago and they seemed fine. Why would steering cause a belt to go loose like that (if thats even the problem to begin with) Never makes the noise when going straight or starting up. I noticed from other cars that it seemed like loose belts make their infamous scream when the car is started up or goosed a bit.
Old Sep 7, 2004 | 06:28 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
When you turn the wheel there is an increased load on the power stearing pump. That could cause the belt to slip. Also check to make sure you have enuf fluid in the reservoir for the power steering.
Old Sep 7, 2004 | 06:32 PM
Engine: 355 TPI
ah ok I see now.
I'll give it a second look over today. I'll check for the power steering reservoir.
SlowAZ28
Aug 31, 2015 07:56 PM
wild1
Aug 27, 2015 09:01 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
