smoking, smell, and dying problems please help!!!
Old Sep 7, 2004 | 11:02 PM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
Transmission: 700-r4
Ok today i was startin up my car to go home from school and poof a big bluish kinda cloud came out my exhaust. Later when i got it home and started it up after it had been sitting to see if it would do it again. It did this time with a very bad smell and there was a little smoke comming out of the passenger side pipe constantly. Also my car has been dying out of no where at stop lights, signs, whenever i have to come to a stop is when it happens. It has happend 3 times in the past week and its really starting to annoy me. The car doesnt sputter or anything it just dies without warning. Cat has also been popping for some reason...maybe unburned fuel. Dont know where to start on any of this. Please help!!! I need suggestions!!!
Old Sep 7, 2004 | 11:08 PM
sellmanb's Avatar
Car: '86 Berlinetta
blueish smoke = oil
since it's smoke on startup it is most likely your valve seals.
if it happens while you're driving too then it is possibly your piston rings.
If you car is just dieing, and not sputtering, while you're at a stop light, you might want to check your belts, an extremely loose belt around the alternator could cause that. No sputtering when dieing is normally electrically related. I'd also have your ignition module checked 1st thing. It could leave you stranded somewhere.
bryan623
Mar 22, 2021 06:43 PM
chazman
Aug 28, 2018 03:25 PM
dyeager535
Aug 28, 2015 08:10 AM
chazman
Aug 22, 2015 02:01 PM
