Throttle Blades
Old May 4, 2001 | 01:18 AM
Raymond 5.7 89 Formula's Avatar
Throttle Blades
I had someone mash the gas pedal all the way down while I checked throttle blades. It seems that they open almost all the way except that I can still push them open a little more with my hands pushing on the linkage all the way till you hit a stop.Should they go all the way to the stop by just pushing on the gas pedal? And if so what can I do? Thanks for any info.
SLP 1 5/8 Headers,ATR catback exhaust,SLP cold air box,Crane 1:6 roller rockers,Bosch plugs and MSD wires,MSD Coil,Fastchip,Borg Warner 9 bolt 3:27,Corvette Servo,ROH ZS 17X9.5 Goodyear GSC,s 275/40/17
[This message has been edited by Raymond 5.7 89 Formula (edited May 03, 2001).]
Old May 9, 2001 | 01:28 AM
anyone?
Old May 9, 2001 | 08:11 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
When you mash the gas all the way to the floor, the throttle blades should be "lying flat" on the TB bore. (all the way open) If not, you may want to replace, or attempt to adjust your throttle cable, they do stretch over time. (also, I do not believe there is any adjustment provisions on these, so, you will have to come up with something...)
have fun
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Z28/ZR1
Oct 23, 2015 01:04 PM
Giocio
Oct 1, 2015 12:20 PM
dusterbd
Sep 29, 2015 08:40 AM
