Fuel pump question?
Fuel pump question?
I'm fixen to put a larger intank fuel pump in my car. (86 camaro)
What all do you have to remove to drop the fuel tank....
I've heard the rearend, I hope not.
I know the exaust will have to drop.
How long should this project take...
I just replace my fuel pump this weekend in my '91 Formula. I ain't gonna lie to you..its not fun. The rear axle has to be dropped down (unbolt shocks, remove trackbar & trackbar brace, disconnect sway bar, remove springs..acutally they will fall out as you lower it.) It took probably 8 hours total to do. If all the bolts come right out and not problems, probably less time. I had some bolts that had to be cut out and some came right off. Just remember to get the rear end as high as you can so you can drop the axle as far as possible (make sure to disconnect the brake lines so you dont stretch them!) Its nothing thats real hard, just takes time and the right tools.
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
