350 or 383?
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
350 or 383?
I am thinking about building an engine and then finding a thirdgen to put it in. I'm wondering what is better for a thirdgen application. I know that the 383 is a torque monster, but then is it limited up top? Is there a significant cost difference between building the two of them? I'm aiming for a strret car that I can run on the track, and don't know how realistic it is, but I'd also like to be able to run 11's in the quarter. So which motor would you choose for this and why?
Car: 91 rs
Engine: 250
Axle/Gears: stock??
i'd go with the 383 you cna make alot more power. they make good kits for it. remeber thiers no replacemnt for dispalcement. and you can have a high reving 383 it all depends on how you build it. it's gonna eb a lil more costly yes. but you'll be able to run the 11's easyer. 450 out of a mild 383 is good. my firends is just a cast parts in a kit pushing 450 dyno was like 446 or something so it's a nice engien. good pair of heads proted. good valuve train. and good cam you'll be set. i say 383
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
i have to agree unless your going with juice or turbo go with the 383 itll be easier to aquire that 1/4 mi. goal in the end . not that you cant go either on the 383 itll just be easier to acquire the n/a engine and times with a 383 over a 350 in the end
definatly go with the 383
Car: 88 IROC-Z
Engine: 5.7 TPI 350
Im thinking about rebuilding my motor in about 2 or 3 years but I also wanted to install a supercharger and a little shot of NOS but what is better to stick with 350 or bump up to a 383? I wanna keep the same fuelinjection and keep the car looking stock kinda like that sleeper look :rockon: Thanks for any advice you can give me.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Car: 91 rs
Engine: 250
Axle/Gears: stock??
i'm gonna be buiding a 383 tt. so i'm kinda biast. but thier are really cool things you can do. 383 350 same black diffren't bore. just use the parts you want the app. to be for.such as a higher reving motor. use diffren't values and springs and heads. with a nice cam. and you'll be good. thier also more to it then that of course. but i'm just saying thiers no replacement for dispacment. i would tt a 572 but not enough doe$$
a twin tubo 383 sounds like a fun project to me i bet it will put up some serious numbers
Car: 91 rs
Engine: 250
Axle/Gears: stock??
no. not form what i've read tlaked abotu and herd form some buddys of myn. but rember these are just buddys. and i've done some digging of my own. but all it came down to is just build a low comperssion. thats about it. which would be flat top pistons. a bigger combotion chamber head. so on. then get some piping costum fitted for you hair dryer and their you go. but thats the basic conecpt of it
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I would definately go with a 383 or 406 SBC especially if you plan on driving it on the street. An 11 sec 406 will normally have better street manners than an 11 sec 355. The larger the displacement the less radical you have to get with your combination to achieve your 11 sec goal. It will cost slightly more to build a 383 or 406 but its worth the money.
Transmission: 4L80E/4L80E
Yep, a 383 is a "torque monster", especially with a "3/4 cam".
11's in the quarter requires a roll bar at an NHRA track. A nice convience on the street.
(Just an appeal to put down the magazines and pick up the rule book.)
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
