knocks...
Old Sep 12, 2004 | 02:57 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
knocks...
ok well i put a couple new pluggss in today they both broke gettign them out tos ee how the egnien is runnin. shows how offten the previous owner changed them. yeah well i put the ac delcos 25's in thier cause i'm putting a new motor in this winter. but. i start the car and i hear a chater... kinda like it's coming form the cyl 3. i was like wtf. mayb this could be the orcker arms. or what i dunno what a knock really sounds like. never had that problame before. so any help would be nice
Old Sep 12, 2004 | 03:35 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
did it make this noise before you changed the plugs ???
if not check to see if you put the right plugs ( proper length ) in and its not hitting the top of the piston .
i have seen this more than once on peoples vehicles ive worked on because it had a "knock"
Old Sep 12, 2004 | 06:20 PM
ljnowell's Avatar
Also, double and triple check to make sure the plug is good and snug.
Old Sep 12, 2004 | 08:28 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
did you happen to dorp any thing into where the spark plug screws in to? that could be your "knock" as well. ive seen it a couple times. resulting in this
Old Sep 12, 2004 | 09:33 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
3 common "knocksh" noises:
1.) ticking noise: generally associated with a bad valve lash setting or an exhaust leak. This is kinda, but not really bad.
2.) pinging: I've seen this described as the sound of marbles in a coffee can. Detonation is occuring. This is bad.
3.) engine knock: spund bearing, usually the rods, perhaps a main. It's a dull metallic thunking coming from the center of the block. This is really bad.
Old Sep 12, 2004 | 10:02 PM
bobsroc's Avatar
Car: 1987 IROCZ
I might add this, check your wires, make sure you don't cross them??? Did you break the plug for cylinder 3 by chance? Might check it for damage.
Old Sep 12, 2004 | 10:09 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
ok i took the spark plugs out i had in i'm just replacng the one i broke and the other one i took out till i can get it to my shop and lean the car out it's running a lil rich. but. both looked good. it really could be a valuve. that would make more sense. spark plug was the same size also. just a lil better plug kinda loner on the withe though. other wise thier nice a snug. i've ruled out detonation. cause i'm sure i don't have a 10.5 or high compression ratio. and it sounds like it's coming from the top of cyl 3. i'm gonna take off the valuve cover and see wahts going on. thanks for the help. ohh and afet a mild drive and letting it sit in idle the plugs seems white with a lol bit og black. dunno were that came form it was spotted in diffrent' palces. .... proablly a bad thing. i just used some lucaus oil stabilzer. and it seems to help seal alot up. car doens' smoke bad when i start it in the morings. no more puff of blue. i'll post waht i find tommaorw
Old Sep 13, 2004 | 08:25 AM
THEGENERAL's Avatar
not to be a smart *** or anything man ..i mean i dont use it that often but maybe you should use the preview reply button before you reply or post ....
and check some of your spelling its a little off and kind of hard to decifer some of it i wasnt sure if you were going into different languages for a min there or not...
well my punctuation is horrible so i cant really say too much ...lol
Old Sep 13, 2004 | 02:49 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
ok i'm sorry. but i don't know how the that added anything to this topic thanks for being a smart ***. i don't get y people say not to be... cause they are. i just didn't have time to do that i'm really busy with school and my car. sorry
Old Sep 14, 2004 | 08:12 AM
THEGENERAL's Avatar
i was just trying to say that you need to slow down a little bit and check some of your spelling it was kindof hard to make out some of the words in there is all im saying .
