13 second cars....
Old May 4, 2001 | 06:23 PM
camaro6spd's Avatar
13 second cars....
What are you running to get into the 13s. I have to rebuild the motor and while the motor is out, I would like to get into the 13s. It would be great if I could use only bolt ons like headers, cat-back, runners, cam etc.
I have a LB9 but it is soon the be a L98. Oh yeah I have the T-5 so don't need and converters of the sort.
Old May 4, 2001 | 06:38 PM
Biochem's Avatar
Car: 2002 SOM z28
Gears will help... 3.73s
Port the heads, get new springs.
New cam... CC262 is a good bet.
350 will get you there a lot easier then a 305.
Carb is good... TPI is good... TBI *****
Traction help will get you there.
Just some suggestions.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old May 4, 2001 | 07:46 PM
ede's Avatar
ede
while you have it down upgrade the cam, maybe pistons, AFPR, flow match the injectors (if port injected), SFCs, gears
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 4, 2001 | 08:00 PM
Spyder's Avatar
TBI is not bad for getting into the 13's. Sure GM did make the motor quite weak but TBI itself is great. In more ways then one it is better then carb, and I would put TBI on before a carb. Cam, Head and you should in high to mid 13's with out a problem. If you want more goto a 350. The 305 can put out a lot of power but its alot easier to do it with a 350. Mine has G-tech'd at 13.9 and another car on the TBI board is doing 13.4.
--Spyder--
1992 Camaro RS
LO3, T-56,centerforce clutch, ported and polished heads, Edelbrock Performer Intake, 14X3 Open Element w/ K&N, hiflow cats with two pipes going back, AC delete, SMOG delete, alu drive shaft, 3.73 posi, 170 stat w/ fan switch, STB, Subframe connectors, KYB AGX, Eagle GSC, and poly bushings.
1982 Z-28
327ci CSB, Turbo 350
Old May 9, 2001 | 06:12 PM
camaro6spd's Avatar
the guy who i bought the camaro from says it has 3.63 gears, do you think he ment 3.73? Ok, what about some headers, cat-back, Copmucam 2032??, has an airfoil, port the plenum and gasket match everything on a 350 TPI motor. Where do you think I will stand in the 1/4 mile and what kind of hp.
Old May 10, 2001 | 03:51 AM
poncho9789's Avatar
I got my 89 from a friend when he ran the car he ran a 13.1 spining through first and most of seciond gear on street radials.That was with everything in my sig and the TPIS superprofile cam,by the way it has 3.20s in the rear
97 formula w/6speed,cags skipshift eleminator, hurst billet pro shifter, 30#injectors,adjustiable fuel presure regulator,Moroso cold air induction,ported mass air sensor,accell300+ ignition box, accell 9000 wires, bosch platnum4 plugs,flomaster crossflow muffler,Lingenfiter 52mm throttle body,TPIS L98 SuperProfile cam,Crane 1:6 full roller rockers,Edelbrock subframe connectors,Edelbrock strut tower brace.
Other car is a 89 GTA w/700r4w/stage 2 shift kit, corvette servo, B&M mega shifter, TPIS bigmouth intake, TPIS large tube runners, TPIS 52mm throttle body,LT1 24# injectors,GMPP LT4 hotcam,CompCams Pro magnum roller rockers, this car is currently under rebuild and restoration.
Old May 10, 2001 | 01:22 PM
Spyder's Avatar
Check out my sig, the 92 is running 13.9 otherwise there was anohter guy that had a LO3 that ran mostly stock with NOS and did 13.5 or so.
--Spyder--
1992 Camaro RS
1982 Z-28
Thornburg
Mid-West Region
Aug 25, 2015 08:20 PM
happyhapka
Jun 19, 2014 09:48 PM
mcbitchman
Mar 13, 2014 04:06 AM
mcbitchman
Mar 11, 2014 12:27 PM
Van Nuys born
May 14, 2013 09:03 AM
