greater timing advance possible with more fuel pressure?
Old May 9, 2001 | 11:21 PM
speedlvr's Avatar
O.K., here's my thought. Take 2 identical cars with the only difference being that one of them has higher fuel pressure. As the timing is advanced, which one will start knocking first?
Old May 10, 2001 | 08:00 AM
speedlvr's Avatar
Stumped?
Old May 10, 2001 | 03:39 PM
The ODB's Avatar
the one with lower pressure will knock first. Extra fuel cools & slows the combustion of gasoline and reduces knock.
The richer you go, the more advance you can run without knock..
however, maximum power is found when you are at the lean limit of combustion at WOT and the spark advance is reduced to the point where knock is only ocurring right after the shift changes.
ie:
a car running @ 11:1 A/F ratio & 40* total timing will NOT run nearly as fast as
a car running @ 13:1 A/F ratio & 34* total.
this is assuming your normal small block chevy V8 engine running on pump gas.
ODB
Old May 10, 2001 | 03:55 PM
Bort62's Avatar
True, true.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old May 10, 2001 | 09:30 PM
speedlvr's Avatar
So it's ok if it knocks, just as long as it's right after the shifts?
Old May 10, 2001 | 09:52 PM
The ODB's Avatar
load induced misfire is normal right after a shift as long as it's very brief and mild.
Old May 10, 2001 | 10:01 PM
The ODB's Avatar
specialized
Jun 18, 2022 09:26 AM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
