Head Removel Problems
Old Sep 16, 2004 | 01:55 AM
408maro's Avatar
Car: 92Rs 25th ann
Engine: 305 TBI
Transmission: auto
ok im helping a friend take his heads of his 88 350 iroc,but i cant get the heads off all the bolts are off the intake is off the serpentine setup is unbolted but still cant get them off,any suggestions please
Old Sep 16, 2004 | 02:17 AM
amean94ta's Avatar
Car: 1994 pontiac trans am gt
Engine: 396 ci lt1 13.6:1 compression
Transmission: extreme evil 4l60e
make sure you got the inside bolts on the ends sometimes they get covered over with sludge that hides them. other than that use a flat head put on head to block seam and hit with the palm of your hand to free it up
Old Sep 16, 2004 | 02:18 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The 34 head bolts? You just list the intake and serpy bolts....just thought I'd ask...
Old Sep 16, 2004 | 10:14 AM
408maro's Avatar
Car: 92Rs 25th ann
Engine: 305 TBI
Transmission: auto
thanks guys,but yea all the head bolts are off
Old Sep 16, 2004 | 10:31 AM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
They are stuck...use a prybar between the chinawall and the head to break it loose
Old Sep 16, 2004 | 02:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You positive?
Counted them?
There should be 34: 16 short ones, 14 long ones, 4 medium ones. Make sure they're all laying there next to the engine. If they're not next to it, they're in it, and that's why the heads are stuck.
One head stuck = stuck, pry it
Two heads stuck = you missed the medium-length bolts on both sides
Old Sep 16, 2004 | 03:16 PM
Eggplant Jeff's Avatar
Thwack 'em really hard with a large dead blow hammer or rubber mallet. Repeatedly.
As long as they're cast iron heads they aren't too delicate, just try not to mess up the gasket surfaces.
Putting a crowbar into one of the water passages and prying works. No valves in there or anything to mess up.
If you can pry a tiny gap and then it closes when you stop prying, you probably missed a bolt. If you have all the bolts out it'll just be a matter of prying/hammering until they suddenly pop loose.
Remember there are alignment dowels so you have to pry AWAY from the block, you will not get them to move sideways no matter what.
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
theurge
Aug 21, 2015 12:46 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
