heating up
Old May 12, 2001 | 08:49 PM
CWIROC's Avatar
heating up
HEATING problem with car. Have replaced thermastat and water pump. Fans come on and water is flowing in and out of rad. by looks.
Car heats up sitting or driving, so that tells me its a waterflow problem. Done compression check and checks out fine.Car still runs like a champ but temp still rises to 260 and i shut it off.
1990 IROC TPI305, MSD 6A, DYNOMAX MUFFLER, MEGASHIFTER, 160 THERMOSTAT, HYPERTECH FAN SWITCH, AND A BLASTER COIL. WITH MORE TO COME!
Old May 12, 2001 | 09:14 PM
El Guapo's Avatar
Time for a cooling system flush, me thinks.
I'd flush the block, and have the radiator boiled out.
Easiest way to flush the block is to use a flush kit then run a water hose to it and let it flow out of the engine till clean water comes out.
The radiator may not be flowing as much as it should, hence not cooling as it should. Thats where boiling it out comes in.
Good luck
Clayton
Old May 12, 2001 | 09:28 PM
CWIROC's Avatar
ya that was my next thing i get car back thursday from paint shop.Fulshing block.if any other ideas please write . I do have alot of calcium buildup in rad. thinking of replacing with griffin.Be cool to $$$$
2000 WS6 and she needs no mods
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
