How do I know?
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
How do I know?
Hello Everyone,
I am going to be swapping my V6 for a 350 TPI very soon. Now my question is how do i know if an engine is internaly balanced or externaly balanced? The 350 I have is just a Block and heads that i pulled from an '87 GMC Sierra. And i need to get a new harmonic balancer because the one that is on the engine now looks broken. Any help would be great.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Originally posted by ME Leigh
It is internal balance, all of them are except 400's and strokers.
Any GM-built small block engine other than a 400 will be internally balanced though
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
he said it's out of an 87- 1 pice rear main seal- they are externaly ballanced for all appclations, but only slightly and only on the flywheel/flexplate side (unlike the 2 peice rear main 400, which has a counterweihgted ballencer and flywheel/flexplate), that's why the bolt patteren changed when they went to the 1 peice.
all SBCs are internally balanced, except the 400. what gets people mixed up that don't have a good handle on engine balancing is the bat wing weight on the flex plate that replaces mass from the flywheel mounting flange
