some ticking noise
Subscribe
Sep 20, 2004 | 08:57 AM
some of my friends said that when i am just putting along at idle, my car makes this popping noise that sounds like its coming from the back of the car. i don't know if this is the exhaust or the rear end. i can hear it bouncin off walls and things that are close to the road when i drive it. does anyone have any suggestions to what it is???
Reply 0
Sep 20, 2004 | 09:00 AM
Hard to tell what a sound is from a written description, but it could be that a heatshield has loosened up a bit. If it makes the noise while you are sitting stoped just get down on the ground and listen around until you can tell where its coming from. I highly doubt its something inside the rearend though.
Reply 0
Sep 20, 2004 | 09:04 AM
ive gotten on the ground and listened all the way around the car and can't hear it. it only does it when movin for some reason. i have no idea what it could be, ill chech the heat shields though.
Reply 0
Sep 20, 2004 | 09:21 AM
could be numerous things u-joints , brakes , exhaust , heatshields, something caught in your tire....could be anything look into those first...
Reply 0
Sep 20, 2004 | 09:28 AM
ill check all that stuff asap
Reply 0
Subscribe
